A hybridizable discontinuous Galerkin method with characteristic variables for Helmholtz problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2023
A new hybridizable discontinuous Galerkin method, named the CHDG method, is proposed for solving time-harmonic scalar wave propagation problems. This method relies on a standard discontinuous Galerkin scheme with upwind numerical fluxes and high-order polynomial bases. Auxiliary unknowns corresponding to characteristic variables are defined at the interface between the elements, and the physical fields are eliminated to obtain a reduced system. The reduced system can be written as a fixed-point problem that can be solved with stationary iterative schemes. Numerical results with 2D benchmarks are presented to study the performance of the approach. Compared to the standard HDG approach, the properties of the reduced system are improved with CHDG, which is more suited for iterative solution procedures. The condition number of the reduced system is smaller with CHDG than with the standard HDG method. Iterative solution procedures with CGN or GMRES required smaller numbers of iterations with CHDG.
PostprintCHDG.pdf (3.23 Mo) Télécharger le fichier
hal-03909368 , version 1 (21-12-2022)
hal-03909368 , version 2 (12-09-2023)
Paternité
Axel Modave, Théophile Chaumont-Frelet. A hybridizable discontinuous Galerkin method with characteristic variables for Helmholtz problems. Journal of Computational Physics, 2023, 493, pp.112459. ⟨10.1016/j.jcp.2023.112459⟩. ⟨hal-03909368v2⟩
203 Consultations
147 Téléchargements
