BV and Pomset Logic Are Not the Same - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
BV and pomset logic are two logics that both conservatively extend unit-free multiplicative linear logic by a third binary connective, which (i) is non-commutative, (ii) is self-dual, and (iii) lies between the "par" and the "tensor". It was conjectured early on (more than 20 years ago), that these two logics, that share the same language, that both admit cut elimination, and whose connectives have essentially the same properties, are in fact the same. In this paper we show that this is not the case. We present a formula that is provable in pomset logic but not in BV.
LIPIcs-CSL-2022-32.pdf (873.61 Ko) Télécharger le fichier
hal-03909463 , version 1 (21-12-2022)
Lê Thành Dung Nguyên, Lutz Straßburger. BV and Pomset Logic Are Not the Same. CSL 2022 - 30th EACSL Annual Conference on Computer Science Logic, Feb 2022, Göttingen, Germany. ⟨10.4230/LIPIcs.CSL.2022.32⟩. ⟨hal-03909463⟩
54 Consultations
21 Téléchargements
