Primitive Equations Under Location Uncertainty: Analytical Description and Model Development - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
Abstract Resolving numerically all the scale interactions of ocean dynamics in a high resolution realistic configuration is today far beyond reach, and only large scale representations can be afforded. In this work, we study a stochastic parameterization of the ocean primitive equations derived within the modelling under location uncertainty framework. First numerical assessments built with the NEMO core’s code are provided for a double-gyres configuration.
978-3-031-18988-3_18.pdf (544.4 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03910760 , version 1 (23-01-2023)
Francesco Tucciarone, Etienne Mémin, Long Li. Primitive Equations Under Location Uncertainty: Analytical Description and Model Development. Stochastic Transport in Upper Ocean Dynamics, 10, Springer International Publishing, pp.287-300, 2023, Mathematics of Planet Earth, ⟨10.1007/978-3-031-18988-3_18⟩. ⟨hal-03910760⟩
321 Consultations
58 Téléchargements
