A Two-Step Numerical Scheme in Time for Surface Quasi Geostrophic Equations Under Location Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abstract In this work we consider the surface quasi-geostrophic (SQG) system under location uncertainty (LU) and propose a Milstein-type scheme for these equations, which is then used in a multi-step method. The SQG system considered here consists of one stochastic partial differential equation, which models the stochastic transport of the buoyancy, and a linear operator linking the velocity and the buoyancy. In the LU setting, the Euler-Maruyama scheme converges with weak order 1 and strong order 0.5. Our aim is to develop higher order schemes in time, based on a Milstein-type scheme in a multi-step framework. First we compared different kinds of Milstein schemes. The scheme with the best performance is then included in the two-step scheme. Finally, we show how our two-step scheme decreases the error in comparison to other multi-step schemes.
978-3-031-18988-3_5.pdf (434.71 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03910769 , version 1 (23-01-2023)
Camilla Fiorini, Pierre-Marie Boulvard, Long Li, Etienne Mémin. A Two-Step Numerical Scheme in Time for Surface Quasi Geostrophic Equations Under Location Uncertainty. STUOD 2021 - Workshop on Stochastic Transport in Upper Ocean Dynamics, Sep 2021, London (UK), United Kingdom. pp.57-67, ⟨10.1007/978-3-031-18988-3_5⟩. ⟨hal-03910769⟩
176 Consultations
43 Téléchargements
