Stochastic Parameterization with Dynamic Mode Decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
Abstract A physical stochastic parameterization is adopted in this work to account for the effects of the unresolved small-scale on the large-scale flow dynamics. This random model is based on a stochastic transport principle, which ensures a strong energy conservation. The dynamic mode decomposition (DMD) is performed on high-resolution data to learn a basis of the unresolved velocity field, on which the stochastic transport velocity is expressed. Time-harmonic property of DMD modes allows us to perform a clean separation between time-differentiable and time-decorrelated components. Such random scheme is assessed on a quasi-geostrophic (QG) model.
978-3-031-18988-3_11.pdf (1.41 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03910774 , version 1 (23-01-2023)
Long Li, Etienne Mémin, Gilles Tissot. Stochastic Parameterization with Dynamic Mode Decomposition. Stochastic Transport in Upper Ocean Dynamics, 10, Springer International Publishing, pp.179-193, 2023, Mathematics of Planet Earth, ⟨10.1007/978-3-031-18988-3_11⟩. ⟨hal-03910774⟩
348 Consultations
75 Téléchargements
