Statistical analysis of Mapper for stochastic and multivariate filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied and Computational Topology Année : 2022
Reeb spaces, as well as their discretized versions called Mappers, are common descriptors used in Topological Data Analysis, with plenty of applications in various fields of science, such as computational biology and data visualization, among others. The stability and quantification of the rate of convergence of the Mapper to the Reeb space has been studied a lot in recent works [BBMW19, CO17, CMO18, MW16], focusing on the case where a scalar-valued filter is used for the computation of Mapper. On the other hand, much less is known in the multivariate case, when the codomain of the filter is Rp, and in the general case, when it is a general metric space (Z, dZ ), instead of R. The few results that are available in this setting [DMW17, MW16] can only handle continuous topological spaces and cannot be used as is for finite metric spaces representing data, such as point clouds and distance matrices. In this article, we introduce a slight modification of the usual Mapper construction and we give risk bounds for estimating the Reeb space using this estimator. Our approach applies in particular to the setting where the filter function used to compute Mapper is also estimated from data, such as the eigenfunctions of PCA. Our results are given with respect to the Gromov-Hausdorff distance, computed with specific filter-based pseudometrics for Mappers and Reeb spaces defined in [DMW17]. We finally provide applications of this setting in statistics and machine learning for different kinds of target filters, as well as numerical experiments that demonstrate the relevance of our approach.
hal-03912325 , version 1 (24-12-2022)
Mathieu Carriere, Bertrand Michel. Statistical analysis of Mapper for stochastic and multivariate filters. Journal of Applied and Computational Topology, 2022, 6 (3), pp.331-369. ⟨10.1007/s41468-022-00090-w⟩. ⟨hal-03912325⟩
34 Consultations
0 Téléchargements
