Model-Driven Generation of Microservice Interfaces: From LEMMA Domain Models to Jolie APIs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We formally define and implement a translation from domain models in the LEMMA modelling framework to microservice APIs in the Jolie programming language. Our tool enables a software development process whereby microservice architectures can first be designed with the leading method of Domain-Driven Design, and then corresponding data types and service interfaces (APIs) in Jolie are automatically generated. Developers can extend and use these APIs as guides in order to produce compliant implementations. Our tool thus contributes to enhancing productivity and improving the design adherence of microservices.
coordination2022.pdf (532.71 Ko) Télécharger le fichier
hal-03915132 , version 1 (29-12-2022)
Saverio Giallorenzo, Fabrizio Montesi, Marco Peressotti, Florian Rademacher. Model-Driven Generation of Microservice Interfaces: From LEMMA Domain Models to Jolie APIs. 24th IFIP WG 6.1 International Conference, 17th International Federated Conference on Distributed Computing Techniques (DisCoTec 2022), Jun 2022, Lucca, Italy. pp.223-240, ⟨10.1007/978-3-031-08143-9_13⟩. ⟨hal-03915132⟩
64 Consultations
30 Téléchargements
