A free discontinuity approach to optimal profiles in stokes flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales de l'Institut Henri Poincaré C, Analyse non linéaire Année : 2023
In this paper we study obstacles immerged in a Stokes flow with Navier boundary conditions. We prove the existence and regularity of an obstacle with minimal drag, among all shapes of prescribed volume and controlled surface area, taking into account that these shapes may naturally develop geometric features of codimension 1. The existence is carried out in the framework of free discontinuity problems and leads to a relaxed solution in the space of special functions of bounded deformation (SBD). In dimension 2, we prove that the solution is classical.
BCGN_revised.pdf (480.12 Ko) Télécharger le fichier
hal-03920819 , version 1 (03-01-2023)
hal-03920819 , version 2 (05-12-2023)
  • HAL Id : hal-03920819 , version 2
Dorin Bucur, Antonin Chambolle, Alessandro Giacomini, Mickaël Nahon. A free discontinuity approach to optimal profiles in stokes flows. Annales de l'Institut Henri Poincaré C, Analyse non linéaire, In press. ⟨hal-03920819v2⟩
90 Consultations
36 Téléchargements
