Discrete-time formulations as time discretization strategies in data assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
Discrete time formulations as time discretization strategies in data assimilation
Data assimilation combines control theory and scientific computing to propose a set of methods for coupling dynamic models and data sequences for estimation and prediction in all engineering domains. Data assimilation naturally raises the question of how the developed control and optimization methods interact with the discretization of the underlying physical models, in particular their temporal discretization. We would like to present here some of the best known techniques developed for discrete-time models, which are essentially based on a mechanism involving model prediction on the one hand and data correction on the other. We show that they can be considered as specific discretizations of the data assimilation strategies proposed for continuous-time models in the sense of a discretization-and-then-control approach. This paradigm justifies the stability of these prediction-correction schemes, paving the way for convergence properties and justifying their popularity in practice.
moireau-chap7-v2.pdf (481.24 Ko) Télécharger le fichier
hal-03921465 , version 1 (03-01-2023)
Philippe Moireau. Discrete-time formulations as time discretization strategies in data assimilation. Handbook of Numerical Analysis, Numerical Control: Part B, 2, Elsevier; Chapter - 9, In press, Handbook of Numerical Analysis, ⟨10.1016/bs.hna.2022.11.005⟩. ⟨hal-03921465⟩
97 Consultations
84 Téléchargements
