A methodology for assessing computation/communication overlap of MPI nonblocking collectives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Concurrency and Computation: Practice and Experience Année : 2022
By allowing computation/communication overlap, MPI nonblocking collectives (NBC) are supposed to improve application scalability and performance. However, it is known that to actually get overlap, the MPI library has to implement progression mechanisms in software or rely on the network hardware. These mechanisms may be present or not, adequate or perfectible, they may have an impact on communication performance or may interfere with computation by stealing CPU cycles. From a user point of view, assessing and understanding the behavior of an MPI library concerning computation/communication overlap is difficult. In this paper, we propose a methodology to assess the computation/communication overlap of NBC. We propose new metrics to measure how much communication and computation do overlap, and to evaluate how they interfere with each other. We integrate these metrics into a complete methodology. We compare our methodology with state of the art metrics and benchmarks, and show that ours provides more meaningful informations. We perform experiments on a large panel of MPI implementations and network hardware and show when and why overlap is efficient, nonexistent or even degrades performance.
article.pdf (644 Ko) Télécharger le fichier
hal-03922777 , version 1 (04-01-2023)
hal-03922777 , version 2 (04-01-2023)
Alexandre Denis, Julien Jaeger, Emmanuel Jeannot, Florian Reynier. A methodology for assessing computation/communication overlap of MPI nonblocking collectives. Concurrency and Computation: Practice and Experience, 2022, 34 (22), ⟨10.1002/cpe.7168⟩. ⟨hal-03922777v2⟩
71 Consultations
116 Téléchargements
