Local time-frequency fading - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
For efficient analysis of non-stationary signals, such as radar, sonar, speech, music, or general audio, timefrequency (TF) representations are required. They allow performing non-stationary filtering, ie extracting nonstationary "components" in signals. However, ad-hoc procedures are frequently used, whose accuracy is difficult to assess and control. In this contribution, we are interested in such time-frequency filtering, which we define as follows: the attenuation of a given, small region Ω in the time-frequency plane. This problem, addressed in a recent publication, is referred to as time-frequency fading (TFF). We address a local version of TFF, called LTFF, that only exploits a neighborhood Ω of the time-frequency region of interest Ω, which is supposed to be much smaller than the full time-frequency domain. This problem will be referred to as local time-frequency fading. We propose a method for determining such a neighborhood Ω. The local TFF problem is then solved using a variational approach, that minimizes a suitable quadratic objective function. Thus, there is a closed-form solution involving Gabor multipliers.
ICA_2022_ABS-0234.pdf (831.24 Ko) Télécharger le fichier
hal-03923596 , version 1 (04-01-2023)
  • HAL Id : hal-03923596 , version 1
Ama Marina Kreme, Bruno Torrésani, Antoine Deleforge. Local time-frequency fading. ICA 22 - International Congress on Acoustics 2022, Oct 2022, Gyeongju, South Korea. ⟨hal-03923596⟩
37 Consultations
46 Téléchargements
