PENDANTSS: PEnalized Norm-ratios Disentangling Additive Noise, Trend and Sparse Spikes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Signal Processing Letters Année : 2023
Denoising, detrending, deconvolution: usual restoration tasks, traditionally decoupled. Coupled formulations entail complex ill-posed inverse problems. We propose PENDANTSS for joint trend removal and blind deconvolution of sparse peak-like signals. It blends a parsimonious prior with the hypothesis that smooth trend and noise can somewhat be separated by low-pass filtering. We combine the generalized quasi-norm ratio SOOT/SPOQ sparse penalties $\ell_p/\ell_q$ with the BEADS ternary assisted source separation algorithm. This results in a both convergent and efficient tool, with a novel Trust-Region block alternating variable metric forward-backward approach. It outperforms comparable methods, when applied to typically peaked analytical chemistry signals. Reproducible code is provided.
hal-03924136 , version 1 (05-01-2023)
Paul Zheng, Emilie Chouzenoux, Laurent Duval. PENDANTSS: PEnalized Norm-ratios Disentangling Additive Noise, Trend and Sparse Spikes. IEEE Signal Processing Letters, 2023, 30, pp.215-219. ⟨10.1109/LSP.2023.3251891/mm1⟩. ⟨hal-03924136⟩
127 Consultations
0 Téléchargements
