Verifying Attention Robustness of Deep Neural Networks against Semantic Perturbations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2022
It is known that deep neural networks (DNNs) classify an input image by paying particular attention to certain specific pixels; a graphical representation of the magnitude of attention to each pixel is called a saliency-map. Saliency-maps are used to check the validity of the classification decision basis, e.g., it is not a valid basis for classification if a DNN pays more attention to the background rather than the subject of an image. Semantic perturbations can significantly change the saliency-map. In this work, we propose the first verification method for attention robustness, i.e., the local robustness of the changes in the saliency-map against combinations of semantic perturbations. Specifically, our method determines the range of the perturbation parameters (e.g., the brightness change) that maintains the difference between the actual saliency-map change and the expected saliency-map change below a given threshold value. Our method is based on activation region traversals, focusing on the outermost robust boundary for scalability on larger DNNs. Experimental results demonstrate that our method can show the extent to which DNNs can classify with the same basis regardless of semantic perturbations and report on performance and performance factors of activation region traversals.
gbs.pdf (6.36 Mo) Télécharger le fichier
hal-03926254 , version 1 (06-01-2023)
Satoshi Munakata, Caterina Urban, Haruki Yokoyama, Koji Yamamoto, Kazuki Munakata. Verifying Attention Robustness of Deep Neural Networks against Semantic Perturbations. Fujitsu; Inria Paris; École Normale Supérieure. 2022. ⟨hal-03926254⟩
22 Consultations
33 Téléchargements
