Overcoming Label Noise for Source-free Unsupervised Video Domain Adaptation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite the progress seen in classification methods, current approaches for handling videos with distribution shifts in source and target domains remain source-dependent as they require access to the source data during the adaptation stage. In this paper, we present a self-training based source-free video domain adaptation approach (without bells and whistles) to address this challenge by bridging the gap between the source and the target domains. We use the source pre-trained model to generate pseudo-labels for the target domain samples, which are inevitably noisy. We treat the problem of source-free video domain adaptation as learning from noisy labels and argue that the samples with correct pseudo-labels can help in the adaptation stage. To this end, we leverage the cross-entropy loss as an indicator of the correctness of pseudo-labels, and use the resulting small-loss samples from the target domain for fine-tuning the model. Extensive experimental evaluations show that our method termed as CleanAdapt achieves ∼ 7% gain over the source-only model and outperforms the state-of-the-art approaches on various open datasets.
21.pdf (2.96 Mo) Télécharger le fichier
hal-03929619 , version 1 (08-01-2023)
  • HAL Id : hal-03929619 , version 1
Avijit Dasgupta, C. V. Jawahar, Karteek Alahari. Overcoming Label Noise for Source-free Unsupervised Video Domain Adaptation. ICVGIP 2022 - Indian Conference on Computer Vision, Graphics and Image Processing, Dec 2022, Gandhinagar, India. pp.1-9. ⟨hal-03929619⟩
63 Consultations
189 Téléchargements
