A forensic analysis of the Google Home: repairing compressed data without error correction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Digital Investigation Année : 2022
David Naccache
  • Fonction : Auteur
  • PersonId : 928358
Hadrien Barral
Fabien Thomas-Brans
  • Fonction : Auteur
Matthieu Regnery
  • Fonction : Auteur
Rémi Géraud-Stewart
Thibaut Heckmann
Thomas Souvignet
  • Fonction : Auteur
  • PersonId : 950005
This paper provides a detailed explanation of the steps taken to extract and repair a Google Home's internal data. Starting with reverse engineering the hardware of a commercial off-the-shelf Google Home, internal data is then extracted by desoldering and dumping the flash memory. As error correction is performed by the CPU using an undisclosed method, a new alternative method is shown to repair a corrupted SquashFS filesystem, under the assumption of a single or double bitflip per gzip-compressed fragment. Finally, a new method to handle multiple possible repairs using three-valued logic is presented.
Fichier non déposé
hal-03932223 , version 1 (10-01-2023)
Paternité - Pas d'utilisation commerciale
  • HAL Id : hal-03932223 , version 1
David Naccache, Hadrien Barral, Georges-Axel Jaloyan, Fabien Thomas-Brans, Matthieu Regnery, et al.. A forensic analysis of the Google Home: repairing compressed data without error correction. Digital Investigation, 2022, 42 (00), pp.00. ⟨hal-03932223⟩
19 Consultations
0 Téléchargements
