Physical fault injection and side-channel attacks on mobile devices: A comprehensive analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Security Année : 2021
Carlton Shepherd
Konstantinos Markantonakis
  • Fonction : Auteur
Nico van Heijningen
  • Fonction : Auteur
Driss Aboulkassimi
  • Fonction : Auteur
Clément Gaine
Today’s mobile devices contain densely packaged system-on-chips (SoCs) with multi-core, high-frequency CPUs and complex pipelines. In parallel, sophisticated SoC-assisted security mechanisms have become commonplace for protecting device data, such as trusted execution environments, full-disk and file-based encryption. Both advancements have dramatically complicated the use of conventional physical attacks, requiring the development of specialised attacks. In this survey, we consolidate recent developments in physical fault injections and side-channel attacks on modern mobile devices. In total, we comprehensively survey over 50 fault injection and side-channel attack papers published between 2009–2021. We evaluate the prevailing methods, compare existing attacks using a common set of criteria, identify several challenges and shortcomings, and suggest future directions of research.
hal-03933701 , version 1 (10-01-2023)
Carlton Shepherd, Konstantinos Markantonakis, Nico van Heijningen, Driss Aboulkassimi, Clément Gaine, et al.. Physical fault injection and side-channel attacks on mobile devices: A comprehensive analysis. Computers and Security, 2021, 111, pp.102471. ⟨10.1016/j.cose.2021.102471⟩. ⟨hal-03933701⟩
21 Consultations
0 Téléchargements
