Medical Equipment Used for Forensic Data Extraction: A low-cost solution for forensic laboratories not provided with expensive diagnostic or advanced repair equipment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Forensic Science International: Digital Investigation Année : 2021
Abstract This paper presents an efficient algorithm for computing 11 th -power residue symbols in the cyclo-tomic field ℚ ( ζ 11 ) , $ \mathbb{Q}\left( {{\zeta }_{11}} \right), $ where 11 is a primitive 11 th root of unity. It extends an earlier algorithm due to Caranay and Scheidler (Int. J. Number Theory, 2010) for the 7 th -power residue symbol. The new algorithm finds applications in the implementation of certain cryptographic schemes.
hal-03933704 , version 1 (10-01-2023)
Marc Joye, Oleksandra Lapiha, Ky Nguyen, David Naccache. Medical Equipment Used for Forensic Data Extraction: A low-cost solution for forensic laboratories not provided with expensive diagnostic or advanced repair equipment. Forensic Science International: Digital Investigation, 2021, 36 (1), pp.301092. ⟨10.1016/j.fsidi.2020.301092⟩. ⟨hal-03933704⟩
18 Consultations
0 Téléchargements
