Artificial Neural Network Comparison on hERG Channel Blockade Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Applications Année : 2022
This work will present a comparison of several Artificial Neural Network methods for a classification problem related to cardiac safety assessment. Given the extracellular field potential recorded by means of micro-electrode arrays, the aim is to determine whether a given chemical drug is altering the electrical activity of cardiomyocytes by disrupting the normal behavior of the hERG channels. To do so, this work has considered four different Neural Network methods and compared them in terms of accuracy and computational costs. The conclusion is that, among the tested architectures, the Multilayer Perceptron (MLP) and multivariate 1-dimensional Convolutional Neural Network (1D-CNN) give the most promising results.
liu-2022-ijca-922119.pdf (273.18 Ko) Télécharger le fichier
hal-03934224 , version 1 (11-01-2023)
  • HAL Id : hal-03934224 , version 1
Haibo Liu, Tessa de Korte, Sylvain Bernasconi, Christophe Bleunven, Damiano Lombardi, et al.. Artificial Neural Network Comparison on hERG Channel Blockade Detection. International Journal of Computer Applications, 2022. ⟨hal-03934224⟩
53 Consultations
31 Téléchargements
