Generalization Bounds using Lower Tail Exponents in Stochastic Optimizers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite the ubiquitous use of stochastic optimization algorithms in machine learning, the precise impact of these algorithms and their dynamics on generalization performance in realistic non-convex settings is still poorly understood. While recent work has revealed connections between generalization and heavy-tailed behavior in stochastic optimization, this work mainly relied on continuous-time approximations; and a rigorous treatment for the original discrete-time iterations is yet to be performed. To bridge this gap, we present novel bounds linking generalization to the lower tail exponent of the transition kernel associated with the optimizer around a local minimum, in both discrete- and continuous-time settings. To achieve this, we first prove a data- and algorithm-dependent generalization bound in terms of the celebrated Fernique-Talagrand functional applied to the trajectory of the optimizer. Then, we specialize this result by exploiting the Markovian structure of stochastic optimizers, and derive bounds in terms of their (data-dependent) transition kernels. We support our theory with empirical results from a variety of neural networks, showing correlations between generalization error and lower tail exponents.
hal-03935798 , version 1 (12-01-2023)
Liam Hodgkinson, Umut Şimşekli, Rajiv Khanna, Michael W. Mahoney. Generalization Bounds using Lower Tail Exponents in Stochastic Optimizers. ICML 2022 - 39th International Conference on Machine Learning, Jul 2022, Baltimore, United States. ⟨hal-03935798⟩
8 Consultations
0 Téléchargements
