Grid is Good: Adaptive Refinement Algorithms for Off-the-Grid Total Variation Minimization - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year : 2023
Axel Flinth
  • Function : Author
Frédéric de Gournay
Pierre Weiss
We propose an adaptive refinement algorithm to solve total variation regularized measure optimization problems. The method iteratively constructs dyadic partitions of the unit cube based on i) the resolution of discretized dual problems and ii) on the detection of cells containing points that violate the dual constraints. The detection is based on upper-bounds on the dual certificate, in the spirit of branch-and-bound methods. The interest of this approach is that it avoids the use of heuristic approaches to find the maximizers of dual certificates. We prove the convergence of this approach under mild hypotheses and a linear convergence rate under additional non-degeneracy assumptions. These results are confirmed by simple numerical experiments.
grid_is_good_flinth_gournay_weiss.pdf (3.44 Mo) Télécharger le fichier
figures/ada1D/table_test.csv (656 B) Télécharger le fichier
figures/ada1D_grad/table_test.csv (1.58 Ko) Télécharger le fichier
figures/ada2D1/table_test.csv (738 B) Télécharger le fichier
figures/ada2D_grad/table_test.csv (776 B) Télécharger le fichier
figures/only_large_cells.svg (58.5 Ko) Télécharger le fichier
Dates and versions
hal-03937286 , version 1 (13-01-2023)
Identifiers
Cite
Axel Flinth, Frédéric de Gournay, Pierre Weiss. Grid is Good: Adaptive Refinement Algorithms for Off-the-Grid Total Variation Minimization: Grid is good. 2023. ⟨hal-03937286⟩
18 View
28 Download
Share
