Event structure semantics for multiparty sessions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Logical and Algebraic Methods in Programming Année : 2023
We propose an interpretation of multiparty sessions as Flow Event Structures, which allows concurrency within sessions to be explicitly represented. We show that this interpretation is equivalent, when the multiparty sessions can be described by global types, to an interpretation of such global types as Prime Event Structures.
cdgS22.pdf (428.29 Ko) Télécharger le fichier
hal-03940191 , version 1 (28-01-2023)
Paternité
Ilaria Castellani, Mariangiola Dezani-Ciancaglini, Paola Giannini. Event structure semantics for multiparty sessions. Journal of Logical and Algebraic Methods in Programming, 2023, 131, ⟨10.1016/j.jlamp.2022.100844⟩. ⟨hal-03940191⟩
94 Consultations
22 Téléchargements
