Energy and Delay Trade-Offs of End-to-End Vehicular Communications using a Hyperfractal Urban Modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Telecommunications - annales des télécommunications Année : 2023
Bartlomiej Blaszczyszyn
Philippe Jacquet
Bernard Mans
  • Fonction : Auteur
  • PersonId : 1089806
Dalia Popescu
  • Fonction : Auteur
We characterize trade-offs between the endto-end communication delay and the energy in urban vehicular communications with infrastructure assistance. Our study exploits the self-similarity of the location of communication entities in cities by modeling them with a hyperfractal model which charaterizes the distribution of mobile nodes and relay nodes by a fractal dimension d F and d r , both larger than the dimension of the embedded map. We compute theoretical bounds for the end-to-end communication hop count considering two different energy-minimizing goals: either total accumulated energy or maximum energy per node. Let δ > 1 be the attenuation factor in the street, we prove that when we aim to a total energy cost of order n (1−δ)(1−α) the hop count for an end-to-end transmission is of order n 1−α/(d F −1) , with α < 1 is a tunable parameter. This proves that for both goals the energy decreases as we allow choosing routing paths of higher length. The asymptotic limit of the energy becomes significantly small when the number of nodes becomes asymptotically large. A lower bound on the network throughput capacity with constraints on path energy is also given. We show that our model fits real deployments where open data sets are available.
ANTE-D-22.pdf (3.35 Mo) Télécharger le fichier
hal-03942997 , version 1 (27-01-2022)
hal-03942997 , version 2 (17-01-2023)
Bartlomiej Blaszczyszyn, Philippe Jacquet, Bernard Mans, Dalia Popescu. Energy and Delay Trade-Offs of End-to-End Vehicular Communications using a Hyperfractal Urban Modelling. Annals of Telecommunications - annales des télécommunications, 2023, special issue on 5+G Network Energy Consumption, Energy Efficiency and Environmental Impact, ⟨10.1007/s12243-022-00939-2⟩. ⟨hal-03942997v2⟩
95 Consultations
69 Téléchargements
