New Attacks from Old Distinguishers Improved Attacks on Serpent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Serpent was originally proposed in 1998 and is one of the most studied block ciphers. In this paper we improve knowledge of its security by providing the current best attack on this cipher, which is a 12-round differential-linear attack with lower data, time and memory complexities than the best previous attacks. Our improvements are based on an improved conditional key guessing technique that exploits the properties of the Sboxes.
Improved_Differential_Linear_Attacks_on_Reduced_Round_Serpent.pdf (479.7 Ko) Télécharger le fichier
hal-03947766 , version 1 (19-01-2023)
Paternité
Marek Broll, Federico Canale, Nicolas David, Antonio Flórez-Gutiérrez, Gregor Leander, et al.. New Attacks from Old Distinguishers Improved Attacks on Serpent. CT-RSA 2022 - Cryptographers’ Track at the RSA Conference, Mar 2022, Virtual, France. pp.484--510, ⟨10.1007/978-3-030-95312-6_20⟩. ⟨hal-03947766⟩
Collections
INRIA INRIA2
29 Consultations
55 Téléchargements
