An OCaml use case for strong call-by-need reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Un usage de la réduction paresseuse forte pour OCaml
We present a use-case for strong call-by-need reduction motivated not by a proof assistant, but by the normalization of module "shapes" in the OCaml compiler for tooling purposes.
shapes-workshop.pdf (287.92 Ko) Télécharger le fichier
hal-03947986 , version 1 (25-01-2023)
  • HAL Id : hal-03947986 , version 1
Gabriel Scherer, Nathanaëlle Courant. An OCaml use case for strong call-by-need reduction. ACM SIGPLAN Workshop on ML 2022 - ML Family Workshop, Benoit Montagu, Sep 2022, Ljubljana, Slovenia. ⟨hal-03947986⟩
55 Consultations
45 Téléchargements
