Parallel approximation of the exponential of Hermitian matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
Approximation parallèle de l'exponentielle de matrices Hermitiennes
In this work, we consider a rational approximation of the exponential function to design an algorithm for computing matrix exponential in the Hermitian case. Using partial fraction decomposition, we obtain a parallelizable method, where the computation reduces to independent resolutions of linear systems. We analyze the effects of rounding errors on the accuracy of our algorithm. We complete this work with numerical tests showing the efficiency of our method and a comparison of its performances with Krylov algorithms.
HKPS.pdf (2.04 Mo) Télécharger le fichier
hal-03948509 , version 1 (20-01-2023)
hal-03948509 , version 2 (28-06-2023)
Frédéric Hecht, Sidi-Mahmoud Kaber, Lucas Perrin, Alain Plagne, Julien Salomon. Parallel approximation of the exponential of Hermitian matrices. 2023. ⟨hal-03948509v2⟩
138 Consultations
91 Téléchargements
