Inexact inner–outer Golub–Kahan bidiagonalization method: A relaxation strategy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Linear Algebra with Applications Année : 2022
We study an inexact inner-outer generalized Golub-Kahan algorithm for the solution of saddle-point problems with a two-times-two block structure. In each outer iteration, an inner system has to be solved which in theory has to be done exactly. Whenever the system is getting large, an inner exact solver is, however, no longer efficient or even feasible and iterative methods must be used. We focus this article on a numerical study showing the influence of the accuracy of an inner iterative solutionon the accuracy of the solution of the block system. Emphasis is further given on reducing the computational cost, which is defined as the total number of inner iterations. We develop relaxation techniques intended to dynamically change the inner tolerance for each outer iteration to further minimize the total number of inner iterations. We illustrate our findings on a Stokes problem and validate them on a mixed formulation of the Poisson problem.
2208.01079.pdf (854.38 Ko) Télécharger le fichier
hal-03960074 , version 1 (20-01-2024)
Paternité - Pas d'utilisation commerciale - Pas de modification
Vincent Darrigrand, Andrei Dumitrasc, Carola Kruse, Ulrich Rüde. Inexact inner–outer Golub–Kahan bidiagonalization method: A relaxation strategy. Numerical Linear Algebra with Applications, 2022, ⟨10.1002/nla.2484⟩. ⟨hal-03960074⟩
47 Consultations
4 Téléchargements
