High-dimensional variable clustering based on sub-asymptotic maxima of a weakly dependent random process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We propose a new class of models for variable clustering called Asymptotic Independent block (AI-block) models, which defines population-level clusters based on the independence of the maxima of a multivariate stationary mixing random process among clusters. This class of models is identifiable, meaning that there exists a maximal element with a partial order between partitions, allowing for statistical inference. We also present an algorithm for recovering the clusters of variables without specifying the number of clusters \emph{a priori}. Our work provides some theoretical insights into the consistency of our algorithm, demonstrating that under certain conditions it can effectively identify clusters in the data with a computational complexity that is polynomial in the dimension. This implies that groups can be learned nonparametrically in which block maxima of a dependent process are only sub-asymptotic. To further illustrate the significance of our work, we applied our method to neuroscience and environmental real-datasets. These applications highlight the potential and versatility of the proposed approach.
AI_block_model.pdf (1.53 Mo) Télécharger le fichier
hal-03969058 , version 1 (02-02-2023)
hal-03969058 , version 2 (23-09-2023)
  • HAL Id : hal-03969058 , version 2
Alexis Boulin, Elena Di Bernardino, Thomas Laloë, Gwladys Toulemonde. High-dimensional variable clustering based on sub-asymptotic maxima of a weakly dependent random process. 2023. ⟨hal-03969058v2⟩
93 Consultations
41 Téléchargements
