Controllability results for a cross diffusion system with a free boundary by a flatness approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Applicandae Mathematicae Année : 2023
We study a one-dimensional cross diffusion system with a free boundary modeling Physical Vapor Deposition. Using the flatness approach, we show several results of boundary controllability for this system in spaces of Gevrey class functions. One of the main difficulties consists in the physical constraints on the state and on the control. More precisely, the state corresponds to volume fractions of the n + 1 chemical species and to the thickness of the film produced in the process, whereas the controls are the fluxes of the chemical species. We obtain the local controllability in the case where we apply n + 1 nonnegative controls and a controllability result for large time in the case where we apply n controls without any sign constraints. We also show in this last case that the controllability may fail for small times. We illustrate these results with some numerical simulations.
CrossDiffusion.pdf (484.82 Ko) Télécharger le fichier
hal-03969875 , version 1 (02-02-2023)
hal-03969875 , version 2 (09-10-2023)
Blaise Colle, Jérôme Lohéac, Takéo Takahashi. Controllability results for a cross diffusion system with a free boundary by a flatness approach. Acta Applicandae Mathematicae, 2023, 187, pp.14. ⟨10.1007/s10440-023-00607-0⟩. ⟨hal-03969875v2⟩
227 Consultations
73 Téléchargements
