Catalyst‐Free Thia‐Michael Addition to alpha‐Trifluoromethylacrylates for 3D Network Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemistry - A European Journal Année : 2023
Thia-Michael additions (1,4-additions of a thiol to a Michael acceptor) are generally catalyzed by an external Brønsted or Lewis base. A spontaneous (uncatalyzed) Michael addition of thiols to a-trifluoromethyl acrylates is described in this article, as well as its application to the very efficient preparation of a thermoset. A thorough mechanistic investigation, based on an experimental kinetic study and on DFT calculations, is presented for the addition of arene- and alkanethiols to tert-butyl trifluoromethyl acrylate in polar aprotic solvents, unveiling a probable solvent-assisted proton transfer in the rate-determining step and a considerable lowering of the energy barrier induced by the CF3 group.
Berne, Catalyst-Free Thia-Michael Addition , 2023.pdf (1.55 Mo) Télécharger le fichier
hal-03972802 , version 1 (03-02-2023)
Dimitri Berne, Sebastien Lemouzy, Pascale Guiffrey, Sylvain Caillol, Vincent Ladmiral, et al.. Catalyst‐Free Thia‐Michael Addition to alpha‐Trifluoromethylacrylates for 3D Network Synthesis. Chemistry - A European Journal, inPress, 29 (20), pp.e202203712. ⟨10.1002/chem.202203712⟩. ⟨hal-03972802⟩
49 Consultations
189 Téléchargements
