Locality-aware batch scheduling of I/O intensive workloads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2022
Ordonnancement de charges de travail intensives en entrées-sorties par lot utilisant la localité des données
Clusters make use of workload schedulers such as the Slurm Workload Manager to allocate computing jobs onto nodes. These schedulers usually aim at a good trade-off between increasing resource utilization and user satisfaction (decreasing job waiting time). However, these schedulers are typically unaware of jobs sharing large input files, which may happen in data intensive scenarios. The same input files may be loaded several times, leading to a waste of resources. We study how to design a data-aware job scheduler that is able to keep large input files on the computing nodes, without impacting other memory needs, and can use previously loaded files to limit data transfers in order to reduce the waiting times of jobs. We present three schedulers capable of distributing the load between the computing nodes as well as re-using an input file already loaded in the memory of some node as much as possible. We perform simulations using real cluster usage traces to compare them to classical job schedulers. The results show that keeping data in local memory between successive jobs and using data locality information to schedule jobs allows a reduction in job waiting time and a drastic decrease in the amount of data transfers.
Les plateformes de calculs utilisent des planificateurs de charges de travail comme le Slurm Workload Manager pour allouer des travaux aux nœuds de calcul. Ces ordonnanceurs visent à équilibrer l'utilisation des ressources et la satisfaction des utilisateurs (réduire le temps d'attente). Cependant, ces ordonnanceurs ne sont pas conscients des travaux partageant des fichiers d'entrée volumineux. Dans certaines situations, la quantité de tels travaux peut être importante. Le même fichier d'entrée peut être chargé plusieurs fois, menant à une perte de ressources. Nous étudions la création d'un ordonnanceur de travaux utilisant la localité des données capable de garder de larges fichiers d'entrées sur les nœuds de calculs tout en préservant les autres besoins en mémoire, et également capable de réutiliser des fichiers déjà chargés afin de limiter les transferts de données et ainsi réduire le temps d'attente des travaux. Nous présentons trois ordonnanceurs capables de distribuer la charge entre les nœuds de calculs ainsi que de réutiliser le plus possible les fichiers d'entrées déjà chargés en mémoire de certains nœuds. Nous avons effectué des simulations en utilisant l'historique d'une vraie plateforme de calcul afin de comparer nos algorithmes à des ordonnanceurs classiques. Les résultats montrent que garder des données en mémoire entre des travaux successifs et utiliser la localité des données pour ordonner les travaux permettent une réduction du temps d'attente des travaux et une diminution drastique de la quantité de transferts de données.
RR-9497.pdf (3.98 Mo) Télécharger le fichier
hal-03993118 , version 1 (27-02-2023)
  • HAL Id : hal-03993118 , version 1
Maxime Gonthier, Loris Marchal, Samuel Thibault, Elisabeth Larsson, Carl Nettelblad. Locality-aware batch scheduling of I/O intensive workloads. RR-9497, ENS Lyon; Inria Bordeaux; Uppsala Universitet. 2022, pp.25. ⟨hal-03993118⟩
56 Consultations
115 Téléchargements
