ChartDetective: Easy and Accurate Interactive Data Extraction from Complex Vector Charts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Extracting underlying data from rasterized charts is tedious and inaccurate; values might be partially occluded or hard to distinguish, and the quality of the image limits the precision of the data being recovered. To address these issues, we introduce a semi-automatic system leveraging vector charts to extract the underlying data easily and accurately. The system is designed to make the most of vector information by relying on a drag-and-drop interface combined with selection, filtering, and previsualization features. A user study showed that participants spent less than 4 minutes to accurately recover data from charts published at CHI with diverse styles, thousands of data points, a combination of different encodings, and elements partially or completely occluded. Compared to other approaches relying on raster images, our tool successfully recovered all data, even when hidden, with a 78% lower relative error.
ChartDetective__CHI2023.pdf (2.83 Mo) Télécharger le fichier
hal-04017638 , version 1 (07-03-2023)
Damien Masson, Sylvain Malacria, Daniel Vogel, Edward Lank, Géry Casiez. ChartDetective: Easy and Accurate Interactive Data Extraction from Complex Vector Charts. CHI 2023 - ACM Conference on Human Factors in Computing Systems, Apr 2023, Hamburg, Germany. ⟨10.1145/3544548.3581113⟩. ⟨hal-04017638⟩
248 Consultations
690 Téléchargements
