Book sections
Motion Planning and Sensor-Guided Manoeuvre Generation for an Autonomous Vehicle
Christian Laugier 1 Philippe Garnier 1 Thierry Fraichard 1 Igor Paromtchik 1 Alexis Scheuer 1
1 SHARP - Automatic Programming and Decisional Systems in Robotics
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes
Abstract : This paper deals with a novel motion control approach for a car-like vehicle evolving in a dynamic and partially known environment. After having briefly presented the overall architecture of the control system and the related Global Trajectory Planner, we will put the emphasis onto the Manoeuver Execution module and its inter-connections with the off-line and the on-line motion planning functions. The key idea of the approach is to plan and carry out sensor-guided manoeuvres: first, a nominal trajectory is generated using a reconstructed model of the world and a prediction of the most likely behaviors of the moving entities; then, the involved motion controls are generated and executed using a reactive scheme for taking into account the unforeseen events. This is done using local trajectories associated with some generic sensor-based manoeuvres. Such trajectories are planned on-line and immediately executed by the system. Experimental results obtained with our automatic car-like vehicle are presented for two types of manoeuvres: lane following/changing and autonomous parallel parking.
Complete list of metadata
https://hal.inria.fr/inria-00000020
Contributor : Alexis Scheuer Connect in order to contact the contributor
Submitted on : Tuesday, May 10, 2005 - 7:01:55 PM
Last modification on : Friday, February 4, 2022 - 3:25:34 AM
Identifiers
  • HAL Id : inria-00000020, version 1
Collections
Citation
Christian Laugier, Philippe Garnier, Thierry Fraichard, Igor Paromtchik, Alexis Scheuer. Motion Planning and Sensor-Guided Manoeuvre Generation for an Autonomous Vehicle. A. Zelinsky Editor. Field and Service Robotics, Springer, 1998. ⟨inria-00000020⟩
Share
Metrics
Record views
241
