The Generic Multiple-Precision Floating-Point Addition With Exact Rounding (as in the MPFR Library) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We study the multiple-precision addition of two positive floating-point numbers in base 2, with exact rounding, as specified in the MPFR library, i.e. where each number has its own precision. We show how the best possible complexity (up to a constant factor that depends on the implementation) can be obtain.
rnc6.pdf (120.07 Ko) Télécharger le fichier
inria-00000026 , version 1 (11-05-2005)
Vincent Lefèvre. The Generic Multiple-Precision Floating-Point Addition With Exact Rounding (as in the MPFR Library). 6th Conference on Real Numbers and Computers 2004 - RNC 6, Nov 2004, Dagstuhl, Germany, pp.135-145. ⟨inria-00000026⟩
557 Consultations
325 Téléchargements
