HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
NetIbis: An Efficient and Dynamic Communication System for Heterogeneous Grids
Olivier Aumage 1 Rutger Hofman 2 Henri Bal 2
1 RUNTIME - Efficient runtime systems for parallel architectures
INRIA Futurs, Université Sciences et Technologies - Bordeaux 1, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
Abstract : Grids are more heterogeneous and dynamic than traditional parallel or distributed systems, both in terms of processors and of interconnects. A grid communication system must handle many issues: first, it must run on networks that are not yet determined when the application is launched, including user-space interconnects; second, it must transparently run on different networks at the same time; third, it should yield performance close to that of specialized communication systems. In this paper, we present NetIbis, a new Java communication system that provides a uniform interface for any underlying intercluster or intracluster network. NetIbis solves the heterogeneity issues posed by Grid computing by dynamically constructing network protocol stacks out of drivers, self-contained building blocks for flexible configuration, with limited functionality per driver. We describe the design and implementation of the major NetIbis drivers for serialization, multicast, reliability, and various underlying networks. We also describe various optimizations for performance, like layer collapsing for the GM driver. We evaluate the performance of NetIbis on several platforms, including a European grid.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/inria-00000031
Contributor : Olivier Aumage Connect in order to contact the contributor
Submitted on : Monday, May 16, 2005 - 3:59:24 PM
Last modification on : Wednesday, February 2, 2022 - 3:54:52 PM
Long-term archiving on: : Thursday, April 1, 2010 - 9:28:47 PM
Identifiers
  • HAL Id : inria-00000031, version 1
Collections
Citation
Olivier Aumage, Rutger Hofman, Henri Bal. NetIbis: An Efficient and Dynamic Communication System for Heterogeneous Grids. Cluster Computing and Grid 2005, Cardiff University, May 2005, Cardiff/UK. ⟨inria-00000031⟩
Share
Metrics
Record views
96
Files downloads
180
