Performance evaluation of the Orca shared-object system, ACM Transactions on Computer Systems, vol.16, issue.1, pp.1-40, 1998. ,
DOI : 10.1145/273011.273014
SILK: Scout Paths in the Linux Kernel, 2002. ,
Highly portable and efficient implementations of parallel adaptive N-body methods, Proceedings of the 1997 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '97, pp.1-20, 1997. ,
DOI : 10.1145/509593.509597
FFPF: Fairly Fast Packet Filters, Proceedings of OSDI'04, 2004. ,
The OKE Corral: Code Organisation and Reconfiguration at Runtime Using Active Linking, Proceedings of IWAN'2002, 2002. ,
DOI : 10.1007/3-540-36199-5_3
Wide-area communication for grids: an integrated solution to connectivity, performance and security problems, Proceedings. 13th IEEE International Symposium on High performance Distributed Computing, 2004., 2004. ,
DOI : 10.1109/HPDC.2004.1323501
URL : https://hal.archives-ouvertes.fr/inria-00000126
The Ensemble System, 1998. ,
A High Performance Java Middleware with a Real Application, Proceedings of the ACM/IEEE SC2004 Conference, 2004. ,
DOI : 10.1109/SC.2004.4
The x-Kernel: an architecture for implementing network protocols, IEEE Transactions on Software Engineering, vol.17, issue.1, pp.64-76, 1991. ,
DOI : 10.1109/32.67579
MAGPIE: MPI's Collective Communication Operations for Clustered Wide Area Systems, PPoPP, pp.131-140, 1999. ,
The click modular router, ACM Transactions on Computer Systems, vol.18, issue.3, pp.263-297, 2000. ,
DOI : 10.1145/354871.354874
Efficient Java RMI for parallel programming, ACM Transactions on Programming Languages and Systems, vol.23, issue.6, pp.747-775, 2001. ,
DOI : 10.1145/506315.506317
A more efficient RMI for Java, Proceedings of the ACM 1999 Conference on Java Grande, pp.152-159, 1999. ,
A Stream Input-Output System, AT&T Bell Labs Technical Journal, vol.63, issue.8, pp.1897-1910, 1984. ,
Ibis: a flexible and efficient Java-based Grid programming environment, Concurrency and Computation: Practice and Experience, vol.9, issue.7-8, pp.1-29, 2002. ,
DOI : 10.1002/cpe.860
Satin, ACM Transactions on Programming Languages and Systems, vol.32, issue.3, 2004. ,
DOI : 10.1145/1709093.1709096
Developing Java Grid Applications with Ibis, 2004. ,
DOI : 10.1007/11549468_48
A framework for protocol composition in Horus, Proceedings of the fourteenth annual ACM symposium on Principles of distributed computing , PODC '95, pp.80-89, 1995. ,
DOI : 10.1145/224964.224974
