Flatness and Monge parameterization of two-input systems, control-affine with 4 states or general with 3 states - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2005
This paper studies Monge parameterization, or differential flatness, of control-affine systems with four states and twocontrols. Some of them are known to be flat, and this implies admitting a Monge parameterization. Focusing on systems outside this class, we describe the only possible structure of such a parameterization for these systems, and give a lower bound on the order of this parameterization, if it exists. This lower-bound is good enough to recover the known results about "(x,u)-flatness" of these systems, with much more elementary techniques.
HAL-Platitude23.pdf (433.38 Ko) Télécharger le fichier
inria-00000040 , version 1 (20-05-2005)
inria-00000040 , version 2 (02-12-2005)
David Avanessoff, Jean-Baptiste Pomet. Flatness and Monge parameterization of two-input systems, control-affine with 4 states or general with 3 states. ESAIM: Control, Optimisation and Calculus of Variations, 2005. ⟨inria-00000040v1⟩
147 Consultations
247 Téléchargements
