Interchangeability preprocessing can improve forward checking search ,
A Chessboard Coloring Problem, The College Mathematics Journal, vol.20, issue.2, pp.106-114, 1989. ,
DOI : 10.2307/2686263
Arc-consistency and arc-consistency again, Artificial Intelligence, vol.65, issue.1, pp.179-190, 1994. ,
DOI : 10.1016/0004-3702(94)90041-8
Using constraint metaknowledge to reduce arc consistency computation, Artificial Intelligence, vol.107, issue.1, pp.125-148, 1999. ,
DOI : 10.1016/S0004-3702(98)00105-2
Refining the basic constraint propagation algorithm, Actes de IJCAI'01, pp.309-315, 2001. ,
Boosting systematic search by weighting constraints, Actes de ECAI'04, pp.146-150, 2004. ,
Fundamental properties of neighbourhood substitution in constraint satisfaction problems, Artificial Intelligence, vol.90, issue.1-2, pp.1-24, 1997. ,
DOI : 10.1016/S0004-3702(96)00018-5
Domain filtering consistencies, Journal of Artificial Intelligence Research, vol.14, pp.205-230, 2001. ,
Eliminating interchangeable values in constraint satisfaction problems, Actes de AAAI'91, pp.227-233, 1991. ,
Exploiting interchangeabilities in constraint satisfaction problems, Actes de IJCAI'93, pp.282-287, 1993. ,
Exploiting Multidirectionality in Coarse-Grained Arc Consistency Algorithms, Actes de CP'03, pp.480-494, 2003. ,
DOI : 10.1007/978-3-540-45193-8_33
Consistency in networks of relations, Artificial Intelligence, vol.8, issue.1, pp.99-118, 1977. ,
DOI : 10.1016/0004-3702(77)90007-8
Arc and path consistency revisited, Artificial Intelligence, vol.28, issue.2, pp.225-233, 1986. ,
DOI : 10.1016/0004-3702(86)90083-4
URL : https://hal.archives-ouvertes.fr/inria-00548487
Contradicting conventional wisdom in constraint satisfaction, 1994. ,
DOI : 10.1007/3-540-58601-6_86
Variable and value ordering heuristics for the job shop scheduling constraint satisfaction problem, Artificial Intelligence, vol.86, issue.1, pp.1-41, 1996. ,
DOI : 10.1016/0004-3702(95)00098-4
AC3 an efficient arc consistency algorithm with a low space complexity. Actes de CP'02, pp.755-760, 2002. ,
Making AC3 an optimal algorithm, Actes de IJCAI'01, pp.316-321, 2001. ,
