Iterated Function Systems and the Global Construction of Fractals, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.399, issue.1817, pp.243-245, 1985. ,
DOI : 10.1098/rspa.1985.0057
Solution of an inverse problem for fractals and other sets, Proc. Natl. Acad. Sci. USA, 1986. ,
DOI : 10.1073/pnas.83.7.1975
Individual GP: an Alternative Viewpoint for the Resolution of Complex Problems, Genetic and Evolutionary Computation Conference, pp.974-981, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00000879
The Analysis of the Behavior of a Class of Genetic Adaptive Systems, 1975. ,
Fractal Image Coding: Some Mathematical Remarks on Its Limits and Its Prospects, Fractal Image Encoding and Analysis, NATO ASI Series F: Computer and System Sciences, pp.117-133, 1998. ,
DOI : 10.1007/978-3-662-03512-2_7
Fractal Image Compression: Theory and Application, 1995. ,
Fractal Image Compression with the Genetic Algorithm, Complexity International, vol.1, pp.25-28, 1994. ,
Hyperbolic Iterated Function Systems and Applications, 1985. ,
Escaping Brittleness: The Possibilities of General Purpose Learning Algorithms Applied to Parallel Rule-Based Systems, Machine Learning: An Artiicial Intelligence Approach, pp.593-623, 1986. ,
Adaptation in natural and artiicial systems, 1975. ,
Fractals and self-similarity, pp.713-747, 1981. ,
Fractal image coding: a review, Proceedings of the IEEE, pp.1451-1465, 1993. ,
DOI : 10.1109/5.241507
Chaotic Optimization and the Construction of Fractals: Solution of an Inverse Problem, Complex Systems, vol.3, pp.37-62, 1989. ,
Genetic algorithms with dynamic niche sharing for multimodal function optimization, Proceedings of IEEE International Conference on Evolutionary Computation, 1995. ,
DOI : 10.1109/ICEC.1996.542701
Evolutionary algorithms and a fractal inverse problem, Biosystems, vol.33, issue.3, pp.221-231, 1994. ,
DOI : 10.1016/0303-2647(94)90007-8
Using Fractal Compression Scheme to Embed a Digital Signature in an Image, Video Techniques and Software for Full-Service Networks, volume 2915 of SPIE Proceedings, pp.108-118, 1996. ,
Manipulation of non-linear IFS attractors using genetic programming, Proceedings of the 1999 Congress on Evolutionary Computation-CEC99 (Cat. No. 99TH8406), pp.1171-1177, 1999. ,
DOI : 10.1109/CEC.1999.782556
URL : https://hal.archives-ouvertes.fr/inria-00000878
Representations for Evolutionary Optimization and Identiication in Structural Mechanics, Genetic Algorithms in Engineering and Computer Sciences, pp.443-464, 1995. ,
Evolutionary Identiication of Macro-Mechanical Models, Advances in Genetic Programming II, pp.467-488, 1996. ,
Flexible Learning of Problem Solving Heuristics Through Adaptive Search, Proceedings of IJCAI83, pp.422-425, 1983. ,
Genetic Algorithms for Fractal Image and Image Sequence Compression, Proceedings Computacion Visual 1997, pp.35-44, 1997. ,
Fractal Geometry and Analysis, The Mandelbrot Festschrift, Iterated Function Systems: Theory, Applications and the Inverse Problem, pp.405-468, 1995. ,
Moment and Collage Methods for the Inverse Problem of Fractal Construction with Iterated Function Systems, Fractal 90 Conference, Fractals in Fundamental and Applied Sciences, pp.271-289, 1991. ,
GALib: A C++ Library of Genetic Algorithm Components ,
A Critical Review of Classiier Systems, Proceedings of the 3 rd International Conference on Genetic Algorithms, pp.244-255, 1989. ,
