OmniORB Home Page ,
Madeleine II: a portable and efficient communication library for high-performance cluster computing, Proceedings IEEE International Conference on Cluster Computing. CLUSTER 2000, 2001. ,
DOI : 10.1109/CLUSTR.2000.889004
MPICH/Madeleine: a true multi-protocol MPI for high performance networks, Proceedings 15th International Parallel and Distributed Processing Symposium. IPDPS 2001, p.51, 2001. ,
DOI : 10.1109/IPDPS.2001.924991
URL : https://hal.archives-ouvertes.fr/inria-00072625
Efficient communications in multithreaded runtime systems, Parallel and Distributed Processing. Proc. 3rd Workshop on Runtime Systems for Parallel Programming (RTSPP '99), volume 1586 of Lect. Notes in Comp. Science, pp.468-482, 1999. ,
DOI : 10.1007/BFb0097932
Integrating Kernel Activations in a Multithreaded Runtime System on top of Linux, Parallel and Distributed Processing. Proc. 4th Workshop on Runtime Systems for Parallel Programming (RTSPP '00), volume 1800 of Lect. Notes in Comp. Science, pp.1160-1167, 2000. ,
DOI : 10.1007/3-540-45591-4_160
Portable Parallel CORBA Objects: An Approach to Combine Parallel and Distributed Programming for Grid Computing, Proc. of the Intl. Euro-Par'01 conf, pp.835-844, 2001. ,
DOI : 10.1007/3-540-44681-8_117
URL : https://hal.archives-ouvertes.fr/inria-00000131
Wide-area implementation of the Message Passing Interface, Parallel Computing, vol.24, issue.12-13, pp.12-131735, 1998. ,
DOI : 10.1016/S0167-8191(98)00075-1
CrispORB: High performance CORBA for system area network, Proceedings of the Eighth IEEE International Symposium on High Performance Distributed Computing, pp.11-18, 1999. ,
Treadmarks: Distributed shared memory on standard workstations and operating systems, Proceedings of the 1994 Winter Usenix Conference, pp.115-131, 1994. ,
The design and performance of a real-time I/O subsystem, Proceedings of the Fifth IEEE Real-Time Technology and Applications Symposium, 1999. ,
DOI : 10.1109/RTTAS.1999.777670
Memory coherence in shared virtual memory systems, Proceedings of the 1986 5th Annual ACM Symposium on Principles of Distributed Computing, pp.229-239, 1986. ,
The implementation of a high performance ORB over multiple network transports, 1998. ,
The implementation of a native ATM transport for a high performance ORB, 1998. ,
BIP: A new protocol designed for high performance networking on Myrinet, 1st Workshop on Personal Computer based Networks Of Workstations (PC-NOW '98), Lect. Notes in Comp. Science conjunction with IPPS, pp.472-485, 1998. ,
DOI : 10.1007/3-540-64359-1_721
MPI code encapsulating using parallel CORBA object, Proceedings. The Eighth International Symposium on High Performance Distributed Computing (Cat. No.99TH8469), pp.3-10, 1999. ,
DOI : 10.1109/HPDC.1999.805276
High-performance local area communication with fast sockets, USENIX '97, pp.257-274, 1997. ,
PVM: A framework for parallel distributed computing, Concurrency, Practice and Experience, pp.315-340, 1990. ,
DOI : 10.1002/cpe.4330020404
