HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Local adaptivity to variable smoothness for exemplar-based image denoising and representation
Charles Kervrann 1 Jérôme Boulanger 1
1 VISTA - Vision spatio-temporelle et active
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : A novel adaptive and exemplar-based approach is proposed for image restoration and representation. The method is based on a pointwise selection of small image patches of fixed size in the variable neighborhood of each pixel. The main idea is to associate with each pixel the weighted sum of data points within an adaptive neighborhood. This method is general and can be applied under the assumption that the image is a locally and fairly stationary process. In this paper, we focus on the problem of the adaptive neighborhood selection in a manner that it balances the accuracy of approximation and the stochastic error, at each spatial position. Thus, the new proposed pointwise estimator automatically adapts to the degree of underlying smoothness which is unknown with minimal a priori assumptions on the function to be recovered. Finally, we propose a practical and simple algorithm with no hidden parameter for image denoising. The method is applied to both artificially corrupted and real images and the performance is very close, and in some cases even surpasses, to that of the already published denoising methods. Also, the method is demonstrated to be valuable for applications in fluorescence microscopy. // Nous proposons une nouvelle méthode adaptative pour la restauration et la représentation d'image. L'idée est de sélectionner dans un voisinage adapté pour chaque pixel, des motifs qui sont des copies légèrement modifiées du motif centré au pixel considéré. La méthode de restauration, apparentée aux méthodes à noyaux pour la régression non-paramétrique, cherche alors à calculer, en chaque point, une moyenne pondérée des observations sélectionnées dans un voisinage variable spatialement. L'optimisation de la taille du voisinage repose ici sur un compromis biais/variance de l'estimateur. L'algorithme final, dirigé par les données, est d'une grande simplicité et nécessite à peine l'ajustement d'un faible nombre de paramètres. Nous présentons une comparaison avec des algorithmes conventionnels et des résultats expérimentaux qui mettent en évidence le potentiel de cette méthode pour traiter des situations où l'image est un processus localement stationnaire. Cette méthode est très efficace, puisque les performances obtenues dépassent la plupart des méthodes existantes. Elle a également été validée sur des images de microscopie de fluorescence en bio-imagerie.
Document type :
Reports
Complete list of metadata
Cited literature [81 references]  Display  Hide  Download
https://hal.inria.fr/inria-00000166
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Monday, July 18, 2005 - 10:08:24 AM
Last modification on : Friday, February 4, 2022 - 3:22:46 AM
Long-term archiving on: : Thursday, April 1, 2010 - 8:45:42 PM
Identifiers
  • HAL Id : inria-00000166, version 1
Citation
Charles Kervrann, Jérôme Boulanger. Local adaptivity to variable smoothness for exemplar-based image denoising and representation. [Research Report] PI 1733, 2005, pp.60. ⟨inria-00000166⟩
Share
Metrics
Record views
241
Files downloads
202
