Image Decomposition into a Bounded Variation Component and an Oscillating Component, Journal of Mathematical Imaging and Vision, vol.15, issue.3, 2005. ,
DOI : 10.1007/s10851-005-4783-8
URL : https://hal.archives-ouvertes.fr/hal-00202001
Nonlinear Gaussian filters performing edge preserving diffusion, Proc. of 17-th DAGM Symposium, pp.538-545, 1995. ,
DOI : 10.1007/978-3-642-79980-8_63
Fundamental relationship between bilateral filtering, adaptive smoothing, and the nonlinear diffusion equation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.6, pp.844-847, 2002. ,
DOI : 10.1109/TPAMI.2002.1008390
A common framework for nonlinear diffusion, adaptive smoothing, bilateral filtering and mean shift, Image and Vision Computing, vol.22, issue.1, pp.73-81, 2004. ,
DOI : 10.1016/j.imavis.2003.08.005
A Variational Approach to Maximum a Posteriori Estimation for Image Denoising, Proc. EMMCVPR'01, pp.19-34, 2001. ,
DOI : 10.1007/3-540-44745-8_2
Visual Reconstruction, 1987. ,
Robust anisotropic diffusion, IEEE Transactions on Image Processing, vol.7, issue.3, pp.421-432, 1998. ,
DOI : 10.1109/83.661192
Edges as Outliers: Anisotropic Smoothing Using Local Image Statistics, Proc. Scale-Space'99, pp.259-270, 1999. ,
DOI : 10.1007/3-540-48236-9_23
A variable window approach to early vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.12, pp.1283-1294, 1998. ,
DOI : 10.1109/34.735802
A TV Flow Based Local Scale Measure for Texture Discrimination, Proc. Eur. Conf. Comp. Vis. (ECCV'04), pp.578-590, 2004. ,
DOI : 10.1007/978-3-540-24671-8_46
Adaptive Spatio-Temporal Restoration for 4D Fluorescence Microscopic Imaging, Proc. Int. Conf. Medical Image Comp. and Computer Assisted Intervention (MICCAI'05), 2005. ,
DOI : 10.1007/11566465_110
A Non-Local Algorithm for Image Denoising, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), p.2004 ,
DOI : 10.1109/CVPR.2005.38
Image Denoising By Non-Local Averaging, Proceedings. (ICASSP '05). IEEE International Conference on Acoustics, Speech, and Signal Processing, 2005., 2005. ,
DOI : 10.1109/ICASSP.2005.1415332
Image Selective Smoothing and Edge Detection by Nonlinear Diffusion, SIAM Journal on Numerical Analysis, vol.29, issue.1, pp.182-193, 1992. ,
DOI : 10.1137/0729012
Regularizing Flows for Constrained Matrix-Valued Images, Journal of Mathematical Imaging and Vision, vol.20, issue.1/2, pp.147-162, 2004. ,
DOI : 10.1023/B:JMIV.0000011324.14508.fb
Mean shift, mode seeking, and clustering, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.8, pp.790-7999, 1995. ,
DOI : 10.1109/34.400568
Edge-Preserving Smoothers for Image Processing, Journal of the American Statistical Association, vol.3, issue.442, pp.526-555, 1998. ,
DOI : 10.1080/01621459.1998.10473702
The variable bandwidth mean shift and data-driven scale selection, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, pp.438-445, 2001. ,
DOI : 10.1109/ICCV.2001.937550
Mean shift: a robust approach toward feature space analysis, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.5, pp.603-619, 2002. ,
DOI : 10.1109/34.1000236
Region Filling and Object Removal by Exemplar-Based Image Inpainting, IEEE Transactions on Image Processing, vol.13, issue.9, pp.1200-1212, 2004. ,
DOI : 10.1109/TIP.2004.833105
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.140.9434
Why Least Squares and Maximum Entropy? An Axiomatic Approach to Inference for Linear Inverse Problems, The Annals of Statistics, vol.19, issue.4, pp.2032-2066, 1991. ,
DOI : 10.1214/aos/1176348385
The contourlet transform: an efficient directional multiresolution image representation, IEEE Transactions on Image Processing, vol.14, issue.12, 2004. ,
DOI : 10.1109/TIP.2005.859376
Ideal spatial adaptation by wavelet shrinkage, Biometrika, vol.81, issue.3, pp.425-455, 1994. ,
DOI : 10.1093/biomet/81.3.425
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.5288
De-noising by soft-thresholding, IEEE Transactions on Information Theory, vol.41, issue.3, pp.613-627, 1995. ,
DOI : 10.1109/18.382009
Texture synthesis by non-parametric sampling, Proceedings of the Seventh IEEE International Conference on Computer Vision, pp.1033-1038, 1999. ,
DOI : 10.1109/ICCV.1999.790383
On the origin of the bilateral filter and ways to improve it, IEEE Transactions on Image Processing, vol.11, issue.10, pp.1141-1151, 2002. ,
DOI : 10.1109/TIP.2002.801126
Adaptive nonlocal filtering: a fast alternative to anisotropic diffusion for image enhancement, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.1, pp.42-48, 1999. ,
DOI : 10.1109/34.745732
Image-based rendering using image-based priors, Proceedings Ninth IEEE International Conference on Computer Vision, 2003. ,
DOI : 10.1109/ICCV.2003.1238625
Learning low-level vision, Proceedings of the Seventh IEEE International Conference on Computer Vision, pp.25-47, 2000. ,
DOI : 10.1109/ICCV.1999.790414
Residual variance and residual pattern in nonlinear regression, Biometrika, vol.73, issue.3, pp.625-633, 1986. ,
DOI : 10.1093/biomet/73.3.625
Stochastic relaxation, Gibbs distributions and the bayesian restoration of images, IEEE Trans. Patt. Anal. Mach. Intell, vol.6, pp.721-741, 1984. ,
Fractal image denoising, IEEE Transactions on Image Processing, vol.12, issue.12, pp.1560-1578, 2003. ,
DOI : 10.1109/TIP.2003.818038
Texture preserving variational denoising using an adaptive fidelity term, Proc. VLSM'03, 2003. ,
Estimation of the Optimal Variational Parameter via SNR Analysis, Proc. Int. Conf. on Scale-Space and PDE methods in Computer Vision, 2005. ,
DOI : 10.1007/11408031_20
A nonlinear gaussian filter applied to images with discontinuities, Journal of Nonparametric Statistics, vol.10, issue.1, pp.21-43, 1997. ,
DOI : 10.2307/2288922
On spatial adaptive estimation of nonparametric regression, Math. Meth. of Statist, vol.6, issue.2, pp.135-170, 1997. ,
Probabilistic estimation of local scale, Proceedings 15th International Conference on Pattern Recognition. ICPR-2000, pp.798-801, 2000. ,
DOI : 10.1109/ICPR.2000.903663
Statistics of images, the TV algorithm of Rudin-Osher-Fatemi for image denoising and an improved denoising algorithm, CAM Report, issue.55, p.2, 2002. ,
Applied nonparametric methods, Handbook of Econometrics, vol.IV, pp.2295-2381, 1994. ,
A Combined Corner and Edge Detector, Procedings of the Alvey Vision Conference 1988, pp.147-151, 1988. ,
DOI : 10.5244/C.2.23
Epitomic analysis of appearance and shape, Proceedings Ninth IEEE International Conference on Computer Vision, pp.34-41, 2003. ,
DOI : 10.1109/ICCV.2003.1238311
Wavelet estimators: adapting to unknown smoothness, Math. Meth. Statist, vol.1, pp.1-20, 1997. ,
Adaptive window size image denoising based on intersection of confidence intervals (ICI) rule, Journal of Mathematical Imaging and Vision, vol.16, issue.3, pp.223-235, 2002. ,
DOI : 10.1023/A:1020329726980
An Adaptive Window Approach for Image Smoothing and Structures Preserving, Proc. Eur. Conf. Comp. Vis. (ECCV'04), pp.132-144, 2004. ,
DOI : 10.1007/978-3-540-24672-5_11
Digital image smoothing and the sigma filter, Computer Vision, Graphics, and Image Processing, vol.24, issue.2, pp.255-269, 1983. ,
DOI : 10.1016/0734-189X(83)90047-6
The nonlinear statistics of high-contrast patches in natural images, Int. J. Comp. Vis, vol.54, pp.1-3, 2003. ,
Sparse geometric image representation with Bandelets, IEEE Trans. on Image Process, 2005. ,
On a Problem of Adaptive Estimation in Gaussian White Noise, Theory of Probability & Its Applications, vol.35, issue.3, pp.454-466, 1990. ,
DOI : 10.1137/1135065
Asymptotically minimax adaptive estimation 1: uppers bounds, SIAM J. Theory of Prob. and Appl, vol.36, issue.4, pp.654-659, 1991. ,
Optimal spatial adaptation to inhomogeneous smoothness: an approach based on kernel estimates with variable bandwidth selectors, Ann. Statist, vol.25, issue.3, pp.929-947, 1997. ,
Edge detection and ridge detection with automatic scale selection, Proceedings CVPR IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.117-154, 1998. ,
DOI : 10.1109/CVPR.1996.517113
Determination of singular points in 2D deformable flow fields, Proceedings., International Conference on Image Processing, 1995. ,
DOI : 10.1109/ICIP.1995.537678
Oscillating patterns in image processing and nonlinear evolution equations, 2002. ,
DOI : 10.1090/ulect/022
Selection of optimal stopping time for nonlinear diffusion filtering, International Journal of Computer Vision, vol.52, issue.2/3, pp.189-203, 2003. ,
DOI : 10.1023/A:1022908225256
On Robust Estimation and smoothing with Spatial and Tonal Kernels, 2004. ,
DOI : 10.1007/1-4020-3858-8_18
Optimal approximations by piecewise smooth functions and associated variational problems, Communications on Pure and Applied Mathematics, vol.3, issue.5, pp.577-685, 1989. ,
DOI : 10.1002/cpa.3160420503
Nonlinear image filtering with edge and corner enhancement, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.8, pp.826-833, 1992. ,
DOI : 10.1109/34.149593
Scale-space and edge detection using anisotropic diffusion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.7, pp.629-239, 1990. ,
DOI : 10.1109/34.56205
Estimating the probability of the presence of a signal of interest in multiresolution single- and multiband image denoising, IEEE Transactions on Image Processing, vol.15, issue.3, 2004. ,
DOI : 10.1109/TIP.2005.863698
Adaptive weights smoothing with applications to image restoration, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.62, issue.2, pp.335-354, 2000. ,
DOI : 10.1111/1467-9868.00235
Image denoising using scale mixtures of gaussians in the wavelet domain, IEEE Transactions on Image Processing, vol.12, issue.11, pp.1338-1351, 2003. ,
DOI : 10.1109/TIP.2003.818640
Fields of Experts: A Framework for Learning Image Priors, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), 2005. ,
DOI : 10.1109/CVPR.2005.160
Nonlinear total variation based noise removal algorithms, Physica D: Nonlinear Phenomena, vol.60, issue.1-4, pp.259-268, 1992. ,
DOI : 10.1016/0167-2789(92)90242-F
Adaptive smoothing: a general tool for early vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.6, pp.514-529, 1991. ,
DOI : 10.1109/34.87339
Evaluation of interest point detectors, International Journal of Computer Vision, vol.37, issue.2, pp.151-172, 2000. ,
DOI : 10.1023/A:1008199403446
URL : https://hal.archives-ouvertes.fr/inria-00548302
Multivariate Density Estimation, 1992. ,
Regression based bandwidth selection for segmentation using Parzen windows, Proceedings Ninth IEEE International Conference on Computer Vision, pp.2-9, 2003. ,
DOI : 10.1109/ICCV.2003.1238307
SUSAN -a new approach to low-level image processing, International Journal of Computer Vision, vol.23, issue.1, pp.45-78, 1997. ,
DOI : 10.1023/A:1007963824710
Estimation of a function with discontinuities via local polynomial fit with an adaptive window choice, The Annals of Statistics, vol.26, issue.4, pp.141-170, 1998. ,
DOI : 10.1214/aos/1024691246
Performance Analysis of the Adaptive Algorithm for Bias-to-Variance Tradeoff, IEEE Transactions on Signal Processing, vol.52, issue.5, pp.1228-1234, 2004. ,
DOI : 10.1109/TSP.2004.826179
Diffusions and Confusions in Signal and Image Processing, J. Math. Imag. Vis, vol.14, issue.3, pp.237-244, 2001. ,
Efficient Beltrami Flow Using a Short Time Kernel, Proc. Int. Conf. Scale-Space Methods in Computer Vision, pp.551-522, 2003. ,
DOI : 10.1007/3-540-44935-3_35
The curvelet transform for image denoising, IEEE Transactions on Image Processing, vol.11, issue.6, pp.670-684, 2002. ,
DOI : 10.1109/TIP.2002.1014998
Bilateral filtering for gray and color images, Sixth International Conference on Computer Vision (IEEE Cat. No.98CH36271), pp.839-846, 1998. ,
DOI : 10.1109/ICCV.1998.710815
On the equivalence of local-mode finding, robust estimation and mean-shift analysis as used in early vision tasks, Object recognition supported by user interaction for service robots, pp.927-930, 2002. ,
DOI : 10.1109/ICPR.2002.1048187
Anisotropic Diffusion in Image Processing, Teubner, 1998. ,
Coherence-enhancing diffusion filtering, International Journal of Computer Vision, vol.31, issue.2/3, pp.111-127, 1999. ,
DOI : 10.1023/A:1008009714131
Local mode filtering, Proceedings of the 2001 IEEE Computer Society Conference on Computer Vision and Pattern Recognition. CVPR 2001, pp.428-433, 2001. ,
DOI : 10.1109/CVPR.2001.990993
Structure adaptive anisotropic image filtering, Image and Vision Computing, vol.14, issue.2, pp.135-145, 1996. ,
DOI : 10.1016/0262-8856(95)01047-5
Eden Fundamentals of digital optics, 1996. ,
Filters, random fields and maximum entropy (FRAME): Towards a unified theory for texture modeling, International Journal of Computer Vision, vol.27, issue.2, pp.107-126, 1998. ,
DOI : 10.1023/A:1007925832420
