On entropy maximisation principle. Applications of Statistics, p.27741, 1977. ,
Formalisation et Inttgration en Vision par Ordinateur, 1999. ,
Nonlinear Parameter Estimation, 1974. ,
Assessing a mixture model for clustering with the integrated classiication likelihood, 1998. ,
A RANSAC-based approach to model tting and its application to nding cylinders in range data, International Joint Conference on Artiicial Intelligence, p.6377643, 1981. ,
Moddlisation et Calibration d'une cammra, AFCET, p.5277536, 1989. ,
Rationalising Kanatani's method of renormalisation in computer vision, Statistical Methods for Image Processing, p.61163, 1999. ,
Applied Regression Analysis, 1981. ,
DOI : 10.1002/9781118625590
Experimental self-calibration from four views, 8th International Conference Image Analysis and Processing (ICIAP'95), p.3077312, 1995. ,
DOI : 10.1007/3-540-60298-4_275
Hierarchical visual perception without calibration, 1996. ,
URL : https://hal.archives-ouvertes.fr/inria-00073694
Non linear minimization and visual localization of a plane Analysis and Synthesis, volume VIII, The 6th International Conference on Information Systems, p.3666371, 2000. ,
Practical Optimization, 1993. ,
Applied Optimal Estimation, 1974. ,
Optimal time and minimum space-time product for reversing a certain class of programs, 1996. ,
URL : https://hal.archives-ouvertes.fr/inria-00073896
Estimation of relative camera positions for uncalibrated cameras, Proceedings of the 2nd European Conference on Computer Vision, p.5799587, 1992. ,
DOI : 10.1007/3-540-55426-2_62
Adaptation in Naturel and Artiicial Systems, 1975. ,
Robust Statistics, 1981. ,
DOI : 10.1002/0471725250
Geometric computation for machine vision, 1992. ,
Automatic singularity test for motion analysis by an information criterion, Proceedings of the 4th European Conference on Computer Vision, p.6977708, 1996. ,
DOI : 10.1007/BFb0015579
Statistical Optimization for Geometric Computation: Theory and Practice, 1996. ,
Statistical optimization and geometric inference in computer vision, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.356, issue.1740, p.130331320, 1998. ,
DOI : 10.1098/rsta.1998.0223
Optimal Estimation, identiication and control. M.I, 1964. ,
Statistical analysis of quadratic problems in computer vision, 1997. ,
Heteroscedastic regression in computer vision: problems with bilinear constraint, The International Journal of Computer Vision, vol.37, issue.2, p.1124, 2000. ,
Analyse Adaptative du Mouvement dans des SSquences Monoculaires non Calibres, 1999. ,
On determining the fundamental matrix: Analysis of diierent methods and experimental results, 1993. ,
A general method for Errors-in-Variables problems in computer vision, Proceedings IEEE Conference on Computer Vision and Pattern Recognition. CVPR 2000 (Cat. No.PR00662), 2000. ,
DOI : 10.1109/CVPR.2000.854727
A theory of self-calibration of a moving camera, International Journal of Computer Vision, vol.1, issue.2, p.1233152, 1992. ,
DOI : 10.1007/BF00127171
Robust regression methods for computer vision: A review, International Journal of Computer Vision, vol.53, issue.1, p.59970, 1991. ,
DOI : 10.1007/BF00127126
The convergence of variable metric methods for nonlinearly constrained optimization calculations, chapter 4, 1978. ,
Numerical Recipes in C, 1988. ,
Introduction to Robust and Quasi-Robust Statistical Methods, 1983. ,
DOI : 10.1007/978-3-642-69389-2
Robust Regression and Outlier Detection, 1987. ,
DOI : 10.1002/0471725382
Numerical Analysis, 1989. ,
URL : https://hal.archives-ouvertes.fr/jpa-00227769
Bias in robust estimation caused by discontinuities and multiple structures. pami, 1997. ,
Geometric motion segmentation and model selection, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.356, issue.1740, p.132111340, 1998. ,
DOI : 10.1098/rsta.1998.0224
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.3878
The development and comparison of robust methods for estimating the fundamental matrix, IJCV, vol.24, issue.3, p.2711300, 1997. ,
Optimal Estimation of Matching Constraints, Workshop on 3D Structure from Multiple Images of Large-scale Environments SMILE'98, Lecture Notes in Computer Science, 1998. ,
DOI : 10.1007/3-540-49437-5_5
URL : https://hal.archives-ouvertes.fr/inria-00548324
The rst order expansion of motion equations in the uncalibrated case, CVGIP: Image Understanding, vol.64, issue.1, p.1288146, 1996. ,
Motion of points and lines in the uncalibrated case, The International Journal of Computer Vision, vol.17, issue.1, p.7742, 1996. ,
Using speciic displacements to analyze motion without calibration, The International Journal of Computer Vision, vol.31, issue.1, p.5529, 1999. ,
Implementing a variant of the Kanatani's estimation method, 2000. ,
Using pseudo Kalman--lters in the presence of constraints, 1992. ,
Using collineations to compute motion and structure in an uncalibrated image sequence, The International Journal of Computer Vision, vol.20, issue.3, p.2133242, 1996. ,
Implicit and explicit camera calibration: Theory and experiments, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.5, p.4699480, 1994. ,
Parameter estimation techniques: a tutorial with application to conic fitting, Image and Vision Computing, vol.15, issue.1, p.59976, 1997. ,
DOI : 10.1016/S0262-8856(96)01112-2
URL : https://hal.archives-ouvertes.fr/inria-00074015
A robust technique for matching two uncalibrated images through the recovery of the unknown epipolar geometry, Artificial Intelligence, vol.78, issue.1-2, 1994. ,
DOI : 10.1016/0004-3702(95)00022-4
URL : https://hal.archives-ouvertes.fr/inria-00074398
