Euler scheme for SDEs with non-Lipschitz diffusion coefficient: strong convergence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Abdel Berkaoui
  • Fonction : Auteur
  • PersonId : 830313
Mireille Bossy
We consider one-dimensional stochastic differential equations in the particular case of diffusion coefficient functions of the form |x|^a, a in [1/2,1). In that case, we study the rate of convergence of a symmetrized version of the Euler scheme. This symmetrized version is easy to simulate on a computer. We prove its strong convergence and obtain the same rate of convergence as when the coefficients are Lipschitz.
RR-5637.pdf (217.29 Ko) Télécharger le fichier
inria-00000176 , version 1 (22-07-2005)
inria-00000176 , version 2 (10-01-2006)
  • HAL Id : inria-00000176 , version 1
Abdel Berkaoui, Mireille Bossy, Awa Diop. Euler scheme for SDEs with non-Lipschitz diffusion coefficient: strong convergence. [Research Report] RR-5637, 2005, 14 p. ⟨inria-00000176v1⟩
Collections
INRIA-RRRT
496 Consultations
1023 Téléchargements
