Termination of rewriting strategies: a generic approach - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2005
We propose a generic termination proof method for rewriting under strategies, based on an explicit induction on the termination property. Rewriting trees on ground terms are modeled by proof trees, generated by alternatively applying narrowing and abstracting steps. The induction principle is applied through the abstraction mechanism, where terms are replaced by variables representing any of their normal forms. The induction ordering is not given a priori, but defined with ordering constraints, incrementally set during the proof. Abstraction constraints can be used to control The narrowing mechanism, well known to easily diverge. The generic method is then instantiated for the innermost, outermost and local strategies.
Not file
Dates and versions
inria-00000178 , version 1 (21-07-2006)
Identifiers
  • HAL Id : inria-00000178 , version 1
Cite
Isabelle Gnaedig, Hélène Kirchner. Termination of rewriting strategies: a generic approach. [Research Report] 2005, pp.49. ⟨inria-00000178⟩
56 View
0 Download
Share
