Abstract : We present here an example of incremental learning between two computational models dealing with different modalities: a model allowing to switch spatial visual attention and a model allowing to learn the ordinal sequence of phonetical numbers. Their merging via a common reward signal allows anyway to produce a cardinal counting behaviour that can be implemented on a robot.
https://hal.inria.fr/inria-00000187 Contributor : Julien VitayConnect in order to contact the contributor Submitted on : Thursday, August 4, 2005 - 12:59:09 PM Last modification on : Friday, February 4, 2022 - 3:33:21 AM
Julien Vitay. Towards Teaching a Robot to Count. Fifth International Workshop on Epigenetic Robotics, L. Berthouze and H. Kozima, Jul 2005, Nara, Japan. ⟨inria-00000187⟩
