A Framework for Optimizing End-to-End Connectivity Degree in Mobile Ad-Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Network and Systems Management Année : 2005
Mobile ad-hoc networks are networks spontaneously deployed from a set of mobile devices without requiring any fixed infrastructures. The increasing interest in this technology raises new research challenges towards providing them a management framework. Network users expect a service level as close as in regular fixed networks. A primary expectation is the capability to communicate (end-to-end) with the other network users. We present in this paper a framework for monitoring and optimizing this capability in mobile ad-hoc networks. Our normalized metric, called end-to-end connectivity degree, characterizes the number of nodes, that a node can reach in the entire network. We describe a management architecture to monitor this metric together with the network density, and illustrate how routing configuration can be performed to optimize it.
Fichier non déposé
inria-00000235 , version 1 (16-09-2005)
  • HAL Id : inria-00000235 , version 1
Rémi Badonnel, Radu State, Olivier Festor, André Schaff. A Framework for Optimizing End-to-End Connectivity Degree in Mobile Ad-Hoc Networks. Journal of Network and Systems Management, 2005, 13 (4). ⟨inria-00000235⟩
42 Consultations
0 Téléchargements
