A finite volume approach for unsteady viscoelastic fluid flows, International Journal for Numerical Methods in Fluids, vol.20, issue.31, pp.939-959, 2002. ,
DOI : 10.1002/fld.353
Galerkin discontinuous approximation of the transport equation and viscoelastic fluid flow on quadrilaterals, Numerical Methods for Partial Differential Equations, vol.36, issue.1, pp.97-114, 1998. ,
DOI : 10.1002/(SICI)1098-2426(199801)14:1<97::AID-NUM6>3.0.CO;2-G
Numerical analysis of a FEM for a transient viscoelastic flow, Computer Methods in Applied Mechanics and Engineering, vol.125, issue.1-4, pp.171-185, 1995. ,
DOI : 10.1016/0045-7825(94)00763-D
Error estimate for the characteristic method involving Oldroyd derivative in a tensorial transport problem, Electronic Journal of Differential Equations, 2004. ,
Characteristics and the finite element method, Proc. 4th Int. Symp. on finite element methods in flow problems, pp.67-73, 1982. ,
Three-Dimensional Finite Element Methods for the Stokes Problem, SIAM Journal on Numerical Analysis, vol.34, issue.2, pp.664-670, 1997. ,
DOI : 10.1137/S0036142994270193
The mathematical theory of finite element methods, 2002. ,
Stability of Higher-Order Hood???Taylor Methods, SIAM Journal on Numerical Analysis, vol.28, issue.3, pp.581-590, 1991. ,
DOI : 10.1137/0728032
Mixed and hybrid finite element methods, 1991. ,
DOI : 10.1007/978-1-4612-3172-1
Approximation of time-dependent, viscoelastic fluid flow: Crank-Nicolson, finite element approximation, Numerical Methods for Partial Differential Equations, vol.15, issue.2, pp.248-283, 2004. ,
DOI : 10.1002/num.10086
Approximation of Time-Dependent Viscoelastic Fluid Flow: SUPG Approximation, SIAM Journal on Numerical Analysis, vol.41, issue.2, pp.457-486, 2003. ,
DOI : 10.1137/S003614290241177X
Méthodes numériques pour la simulation d'´ ecoulements viscoélastiques, Canada, 1986. ,
Analyse num??rique et approche d??coupl??e d'un probl??me d'??coulements de fluides non newtoniens de type Phan-Thien???Tanner : contraintes discontinues, Comptes Rendus de l'Acad??mie des Sciences - Series I - Mathematics, vol.330, issue.10, pp.931-936, 2000. ,
DOI : 10.1016/S0764-4442(00)00282-2
Decoupled approach for the problem of viscoelastic fluid flow of PTT model I: continuous stresses, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.5-7, pp.543-560, 2000. ,
DOI : 10.1016/S0045-7825(99)00426-0
Simulation numérique d'´ ecoulements gravitairesàgravitaires`gravitairesà fortes différences de densité ? Application aux avalanches, 2004. ,
A finite element procedure for viscoelastic flows, International Journal for Numerical Methods in Fluids, vol.10, issue.10, pp.1035-1052, 1987. ,
DOI : 10.1002/fld.1650071004
A new approach for the FEM simulation of viscoelastic flows, Journal of Non-Newtonian Fluid Mechanics, vol.32, issue.3, pp.295-310, 1989. ,
DOI : 10.1016/0377-0257(89)85012-8
On the convergence of the mixed method of Crochet and Marchal for viscoelastic flows, Computer Methods in Applied Mechanics and Engineering, vol.73, issue.3, pp.341-350, 1989. ,
DOI : 10.1016/0045-7825(89)90073-X
Finite element method for Navier-Stokes equations, theory and algorithms, 1986. ,
Hyperbolicity and change of type in the flow of viscoelastic fluis, Arch. Ration. Mech. Anal. pp, pp.213-251, 1985. ,
Two-level finite element discretization of viscoelastic fluid flow, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.44-46, pp.4965-4979, 2003. ,
DOI : 10.1016/S0045-7825(03)00443-2
A decoupled finite element streamline-upwind scheme for viscoelastic flow problems, Journal of Non-Newtonian Fluid Mechanics, vol.31, issue.2, pp.143-162, 1989. ,
DOI : 10.1016/0377-0257(89)80028-X
Finite element approximation of viscoelastic fluid flow using characteristics method, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.42, pp.5603-5618, 2001. ,
DOI : 10.1016/S0045-7825(01)00186-4
A new mixed finite element for calculating viscoelastic flow, Journal of Non-Newtonian Fluid Mechanics, vol.26, issue.1, pp.77-114, 1987. ,
DOI : 10.1016/0377-0257(87)85048-6
Finite Element Approximation of Viscoelastic Fluid Flow: Existence of Approximate Solutions and Error Bounds. Continuous Approximation of the Stress, SIAM Journal on Numerical Analysis, vol.31, issue.2, pp.362-377, 1994. ,
DOI : 10.1137/0731019
A new $\theta $-scheme algorithm and incompressible FEM for viscoelastic fluid flows, ESAIM: Mathematical Modelling and Numerical Analysis, vol.28, issue.1, pp.1-34, 1994. ,
DOI : 10.1051/m2an/1994280100011
Efficient simulation of nonlinear viscoelastic fluid flows, Journal of Non-Newtonian Fluid Mechanics, vol.60, issue.2-3, pp.199-223, 1995. ,
DOI : 10.1016/0377-0257(95)01380-2
Flow characteristics of viscoelastic fluids in an abrupt contraction by using numerical modeling, Journal of Non-Newtonian Fluid Mechanics, vol.52, issue.2, pp.263-288, 1994. ,
DOI : 10.1016/0377-0257(94)80055-3
Convergence and nonlinear stability of the Lagrange-Galerkin method for the Navier-Stokes equations, Numerische Mathematik, vol.10, issue.4, pp.459-483, 1988. ,
DOI : 10.1007/BF01396329
Three dimensional numerical simulations of viscoelastic flows through planar contractions, Journal of Non-Newtonian Fluid Mechanics, vol.74, issue.1-3, pp.195-245, 1998. ,
DOI : 10.1016/S0377-0257(97)00072-4
