Decentralized Case-Based Reasoning for the Semantic Web - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Mathieu d'Aquin
Jean Lieber
Amedeo Napoli
Decentralized case-based reasoning (DzCBR) is a reasoning framework that addresses the problemof adaptive reasoning in amulti-ontology environment. It is a case-based reasoning (CBR) approach which relies on contextualized ontologies in the C-OWL formalism for the representation of domain knowledge and adaptation knowledge. A context in C-OWL is used to represent a particular viewpoint, containing the knowledge needed to solve a particular local problem. Semantic relations between contexts and the associated reasoning mechanisms allowtheCBRprocess in a particular viewpoint to reuse and share information about the problem and the already found solutions in the other viewpoints.
iswc-pour-publi.pdf (578.26 Ko) Télécharger le fichier
inria-00000376 , version 1 (30-09-2005)
Mathieu d'Aquin, Jean Lieber, Amedeo Napoli. Decentralized Case-Based Reasoning for the Semantic Web. 4th International Semantic Web Conference - ISWC 2005, Nov 2005, Galway/Irelande, pp.142-155, ⟨10.1007/11574620⟩. ⟨inria-00000376⟩
99 Consultations
253 Téléchargements
