Abstract : XPath is the standard language for addressing parts of an XML document. We present a sound and complete decision procedure for containment of XPath queries. The considered XPath fragment covers most of the language features used in practice. Specifically, we show how XPath queries can be translated into equivalent formulas in monadic second-order logic. Using this translation, we construct an optimized logical formulation of the containment problem, which is decided using tree automata. When the containment relation does not hold between two XPath expressions, a counter-example XML tree is generated. We provide a complexity analysis together with practical experiments that illustrate the efficiency of the decision procedure for realistic scenarios.
https://hal.inria.fr/inria-00000391 Contributor : Pierre GenevèsConnect in order to contact the contributor Submitted on : Tuesday, October 4, 2005 - 2:58:57 PM Last modification on : Wednesday, April 6, 2022 - 3:48:36 PM Long-term archiving on: : Tuesday, June 2, 2015 - 2:10:14 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : jamais
Pierre Genevès, Nabil Layaïda. A Decision Procedure for XPath Containment. ACM Transactions on Information Systems, Association for Computing Machinery, 2005. ⟨inria-00000391⟩
