Analysis of Technical Documents: The REDRAW System Structured Document Image Analysis, pp.385-402, 1992. ,
The Curvature Primal Sketch, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.8, issue.1, pp.2-14, 1986. ,
DOI : 10.1109/TPAMI.1986.4767747
Shape description using weighted symmetric axis features, Pattern Recognition, vol.10, issue.3, pp.167-180, 1978. ,
DOI : 10.1016/0031-3203(78)90025-0
Using local deviations of vectorization to enhance the performance of raster-to-vector conversion systems, International Journal on Document Analysis and Recognition, vol.3, issue.2, pp.67-72, 2000. ,
DOI : 10.1007/s100320000034
Perfecting Vectorized Mechanical Drawings, Computer Vision and Image Understanding, vol.63, issue.2, pp.273-286, 1996. ,
DOI : 10.1006/cviu.1996.0019
The Second International Graphics Recognition Contest ??? Raster to vector conversion: A report, Graphics Recognition?Algorithms and Systems LNCS, vol.1389, pp.390-410, 1998. ,
DOI : 10.1007/3-540-64381-8_65
Performance evaluation of line drawing recognition systems, Proceedings 15th International Conference on Pattern Recognition. ICPR-2000, pp.4864-4869, 2000. ,
DOI : 10.1109/ICPR.2000.903053
Kalman Filtering for Segment Detection: Application to Music Scores Analysis, Proc. 12th Int'l Conf. Pattern Recognition, pp.301-305, 1994. ,
Well-Shaped, Stable, and Reversible Skeletons from the (3,4)-Distance Transform, Journal of Visual Communication and Image Representation, vol.5, issue.1, pp.107-115, 1994. ,
DOI : 10.1006/jvci.1994.1010
Orthogonal Zig-Zag: An algorithm for vectorizing engineering drawings compared with Hough Transform, Advances in Eng. Software, pp.11-24, 1997. ,
DOI : 10.1016/S0965-9978(96)00035-X
Sparse pixel vectorization: an algorithm and its performance evaluation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.3, pp.202-215, 1999. ,
DOI : 10.1109/34.754586
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.20.1546
Discrete straight line segments: parameters, primitives, and properties, Vision Geometry, Series Contemporary Math, vol.119, pp.45-62, 1991. ,
DOI : 10.1090/conm/119/1113899
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.38.5282
A complete system for the analysis of architectural drawings, International Journal on Document Analysis and Recognition, vol.3, issue.2, pp.102-116, 2000. ,
DOI : 10.1007/PL00010901
TIF2VEC, An Algorithm for Arc Segmentation in Engineering Drawings, Graphics Recognition?Algorithms and Applications, 2002. ,
DOI : 10.1007/3-540-45868-9_31
Random sample consensus: a paradigm for model fitting with applications to image analysis and automated cartography, Communications of the ACM, vol.24, issue.6, pp.381-395, 1981. ,
DOI : 10.1145/358669.358692
A robust algorithm for text string separation from mixed text/graphics images, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.10, issue.6, pp.910-918, 1988. ,
DOI : 10.1109/34.9112
Segmentation Robuste de Courbes Discrètes 2D et Applications a ` la Rétroconversion de Documents Techniques, Thèse de Doctorat, Institut Nat'l Polytechnique de Lorraine, 2004. ,
Improving the Accuracy of Skeleton-Based Vectorization, Graphics Recognition?Algorithms and Applications, 2002. ,
DOI : 10.1007/3-540-45868-9_24
URL : https://hal.archives-ouvertes.fr/inria-00100840
Raster-to-vector conversion by line fitting based on contours and skeletons, Proceedings of 2nd International Conference on Document Analysis and Recognition (ICDAR '93), pp.353-358, 1993. ,
DOI : 10.1109/ICDAR.1993.395716
Adaptive Vectorization of Line Drawing Images, Computer Vision and Image Understanding, vol.65, issue.1, pp.38-56, 1997. ,
DOI : 10.1006/cviu.1996.0484
Unbiased Least Squares Fitting of Circular Arcs, CVGIP: Graphical Models and Image Processing, vol.56, issue.5, pp.424-432, 1994. ,
DOI : 10.1006/cgip.1994.1039
Knowledge-directed interpretation of mechanical engineering drawings, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.9, pp.928-940, 1992. ,
DOI : 10.1109/34.161351
A Statistical, Nonparametric Methodology for Document Degradation Model Validation, IEEE Trans. Pattern Analysis and Machine Intelligence, vol.22, issue.11, pp.1209-1223, 2000. ,
A System for Interpretation of Line Drawings, IEEE Trans. Pattern Analysis and Machine Intelligence, vol.12, issue.10, pp.978-992, 1990. ,
Randomized Hough Transform (RHT) in Engineering Drawing Vectorization System, Proc. IAPR Workshop Machine Vision Applications, pp.173-176, 1990. ,
Thinning methodologies-a comprehensive survey, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.9, pp.869-885, 1992. ,
DOI : 10.1109/34.161346
Geometric Structure Analysis of Document Images: A Knowledge-Based Approach, IEEE Trans. Pattern Analysis and Machine Intelligence, vol.22, issue.12, pp.1224-1240, 2000. ,
Report of the Arc Segmentation Contest Graphics Recognition: Recent Advances and Perspectives, 2004. ,
A Protocol for Performance Evaluation of Line Detection Algorithms, Machine Vision and Applications, pp.5-6, 1997. ,
A theory of multiscale, curvature-based shape representation for planar curves, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.8, pp.789-805, 1992. ,
DOI : 10.1109/34.149591
Engineering drawing processing and vectorization system, Computer Vision, Graphics, and Image Processing, vol.49, issue.3, pp.379-397, 1990. ,
DOI : 10.1016/0734-189X(90)90111-8
Computing circular separability, Discrete & Computational Geometry, vol.12, issue.2, pp.105-113, 1986. ,
DOI : 10.1007/BF02187688
Empirical performance evaluation of graphics recognition systems, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.9, pp.849-870, 1999. ,
DOI : 10.1109/34.790427
An iterative procedure for the polygonal approximation of plane curves, Computer Graphics and Image Processing, vol.1, issue.3, pp.244-256, 1972. ,
DOI : 10.1016/S0146-664X(72)80017-0
Techniques for assessing polygonal approximations of curves, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.19, issue.6, pp.659-666, 1997. ,
DOI : 10.1109/34.601253
Segmentation of edges into lines and arcs, Image and Vision Computing, vol.7, issue.2, pp.109-114, 1989. ,
DOI : 10.1016/0262-8856(89)90004-8
Computer processing of line images: A survey, Pattern Recognition, vol.20, issue.1, pp.7-15, 1987. ,
DOI : 10.1016/0031-3203(87)90013-6
A Hough transform based line recognition method utilizing both parameter space and image space, Pattern Recognition, vol.38, issue.4, pp.539-552, 2005. ,
DOI : 10.1016/j.patcog.2004.09.003
Effective multiresolution arc segmentation: algorithms and performance evaluation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.11, pp.1491-1506, 2004. ,
DOI : 10.1109/TPAMI.2004.103
An object-oriented progressive-simplification-based vectorization system for engineering drawings: model, algorithm, and performance, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.8, pp.1048-1060, 2002. ,
DOI : 10.1109/TPAMI.2002.1023802
On the detection of dominant points on digital curves, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.8, pp.859-872, 1989. ,
DOI : 10.1109/34.31447
Les Distances de Chanfrein en Analyse d'Image: Fondements et Applications, Thèse de Doctorat, 1994. ,
URL : https://hal.archives-ouvertes.fr/tel-00005113
Stable and Robust Vectorization: How to Make the Right Choices, Graphics Recognition?Recent Advances, 2000. ,
DOI : 10.1007/3-540-40953-X_1
URL : https://hal.archives-ouvertes.fr/inria-00099392
Text/Graphics Separation Revisited, Proc. Fifth IAPR Int'l Workshop Document Analysis Systems, 2002. ,
DOI : 10.1007/3-540-45869-7_24
URL : https://hal.archives-ouvertes.fr/inria-00100781
Concurrency of Line Segments in Uncertain Geometry, Proc. 10th Int'l Conf. Discrete Geometry for Computer Imagery, 2002. ,
DOI : 10.1007/3-540-45986-3_26
A fast sequential method for polygonal approximation of digitized curves, Computer Vision, Graphics, and Image Processing, vol.28, issue.2, pp.220-227, 1984. ,
DOI : 10.1016/S0734-189X(84)80023-7
A Survey of Non-Thinning Based Vectorization Methods Advances in Pattern Recognition, Proc. Joint IAPR Workshops SSPR '98 and SPR '98, 1998. ,
Incremental arc segmentation algorithm and its evaluation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.4, pp.424-431, 1998. ,
DOI : 10.1109/34.677280
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.20.1699
Extended Summary of the Arc Segmentation Contest, Graphics Recognition?Algorithms and Applications, pp.273-288, 2002. ,
DOI : 10.1007/3-540-45868-9_30
A System for Performance Evaluation of Arc Segmentation Algorithms, Proc. CVPR Workshop Empirical Evaluation in Computer Vision, 2001. ,
Genericity in graphics recognition algorithms, Lecture Notes in Computer Science, pp.9-20, 1998. ,
DOI : 10.1007/3-540-64381-8_35
Paper-Based Map Processing, Handbook of Character Recognition and Document Image Processing, chapter 19, pp.503-528, 1997. ,
A parallel-line detection algorithm based on HMM decoding, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.5, pp.777-792, 2005. ,
DOI : 10.1109/TPAMI.2005.89
